1993 Buick Regal engine cutting out.
TIM PHELPS
Engine Performance problem
1993 Buick Regal 6 cyl Front Wheel Drive Automatic
Hi fellas. Sure would appreciate some help. any idea why my car would cut out allot until the engne gets hot? Usually happens in cool damp weather. Also what two holes under the dash would I put a jumper wire to get the codes? Thanks a mllion. PS Send me your address I could make a donation to as I don't have a credit card or bank account. T.R.
Feb 16, 2009 at 8:30 AM
DOCFIXIT
  • 18,828 POSTS
Jumper the last two in top row. Key on count flashes
Then post. When you say cuts out is it like a miss?
Feb 17, 2009 at 2:05 AM
TIM PHELPS
Thank you much bud. Yes it is like you're turning the ignition off and on. Runs like they used to when a fuel filter was bad. Thought it was going to strand us today. After the engine gets good and hot it will stop and the check engine light will go out. Thank you again for your help. T.T.
Feb 17, 2009 at 2:46 AM
DOCFIXIT
  • 18,828 POSTS
When you can post codes. When it goes down see if you have spark pull wire hold to block. if good spray some cabr cleaner into air intake,see if it lites
Feb 17, 2009 at 3:16 AM
TIM PHELPS
Will do. Thank you very much. TR
Feb 17, 2009 at 7:53 AM
DOCFIXIT
  • 18,828 POSTS
Off line till tomorrow A.M.
Feb 17, 2009 at 8:54 AM
