1993 Buick Regal driver side brake lights
1993 BUICK REGAL
KAREN MILLER
1993 Buick Regal 130,00 miles
all my lights are working except the back driver side brake lights. i have already changed bulbs. still nothing.
Oct 21, 2008 at 2:29 PM
JDL
  • 16,098 POSTS
Does the turn signal work on the back driver side? On some systems, the turn signal and brake lite use the same bulb filament, just not at the same time.
You might use a testlite on the bulb socket, check voltage, ground, if they're ok, it might be the bulb isn't making good contact in the socket. You might try a dab of lub-grease on the very bottom tip of the bulb, see if that helps.
Maybe you need a new socket.
Oct 22, 2008 at 9:06 AM
