1993 Buick Regal Died won't restart
RONKRBY
  • 5 POSTS
Engine Mechanical problem
1993 Buick Regal 6 cyl Front Wheel Drive Automatic
Checked fuel system and it's good. Started car and it ran for about 15 min. When it die and we got it back to the house, I tried it again. Have no fire. Check to see if it had any codes. No codes. Was wondering what would be the best thing to do? Is there any test I can run to narrow down what the problem is?
Jun 26, 2009 at 2:12 PM
  • 75,988 POSTS
How did you check the fuel system??
Jun 26, 2009 at 2:17 PM
RONKRBY
  • 5 POSTS
[quote:458e1bd4a9="rasmataz"]How did you check the fuel system??[/quote:458e1bd4a9]
I replaced the fuel filter and checked the fuel pressure on the rail.
Jun 26, 2009 at 2:22 PM
RONKRBY
  • 5 POSTS
could the fuel system have something to do with no spark from the coil and no codes?
Jun 26, 2009 at 2:57 PM
RONKRBY
  • 5 POSTS
Here's more information. This started about a week ago. After running for around 15 min. car quits. Was restarting and trying to die but able to get home. I put a new fuel filter on it and it ran good for about 15 min. This time won't restart. I have had coil packs checked and module check auto part store they said they check out but they were not warmed up. When I checked the car the last time it was still warmed up and there was no codes and I didn't have any spark and the plugs. Fuel pressure was good. Checked it with a pressure gauge. Is there anyway to check if it the computer or anyway to rule out certain items. If not I guess I will just start changing items until I find the right one.
Jun 26, 2009 at 3:32 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jun 26, 2009 at 4:45 PM
