1993 Buick Regal acceleration
129,400 MILES • V8 • FWD • AUTOMATIC
RCHAMP47
the engine bucks when you accelerate hard. It seems to happen at speeds of 50 mph or higher.
Nov 7, 2009 at 7:54 AM
  • 75,988 POSTS
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Nov 7, 2009 at 8:14 AM
JEKYLLANTERN
Did you ever get this fixed? My car has the same acceleration problem at 50mph and higher.
Apr 28, 2011 at 5:09 PM
