1992 Buick Regal starter problem
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
PQM BOWEN
car will not start battery starter and plugs all show good.
Oct 13, 2009 at 10:25 AM
  • 75,988 POSTS
If you're talking about its cranking over and will not start-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Oct 13, 2009 at 9:38 PM
