I have a '92 Buick Regal - 3800. Recently my check engine light has started to go on and off. Also my car has picked up an occasional hesitation (runs fine most of the time, but hesitates a little and then comes out of it). I checked the codes and came up with error code 41 (which is the cam sensor signal). I took the car to the shop and they replaced the cam sensor, timing chain, magnet….took the car out and the same thing. I ran the car for awhile and took it back to the shop and they did a few more things and car runs the same. This has been ongoing for a couple years. Now my car died out and want run. I’m tired of spending money at the shop and not getting results. Any ideas what it might be…ICM, Coil Packs, ECM, EGR Valve???? Any assistance would be appreciated.
Apr 5, 2010 at 6:40 AM
