1992 Buick Regal engine dies
180,500 MILES • 6 CYL • 2WD • AUTOMATIC
DWOSLUND
car starts ok - can go for awhile but then starts jerking like its not shifting, the battery needle starts shaking and then the car stops. After five or so minutes it will start up again
Sep 20, 2010 at 12:48 AM
  • 75,988 POSTS
Next time it refuses to start don't wait for it to make up its mind-do below immediately to determine if its fuel or spark.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing.
Sep 23, 2010 at 11:12 PM
