1992 Buick Regal brake lights
DLALVIS
Electrical problem
1992 Buick Regal 6 cyl
how to replace turn signal switch?
Oct 19, 2009 at 3:34 AM
JDL
  • 16,098 POSTS
You have to pull the steering wheel first, my info doesn't show an air-bag? You need a steering wheel puller, the autostore sells them. Make a mark on the steering wheel and shaft before you pull the steering wheel. Make sure the front wheels are pointed straight. There will be a nut on the steering shaft, you need to remove the nut,before using the puller. Are you sure the switch is faulty?
Oct 19, 2009 at 3:58 AM
DLALVIS
yes the switch is faulty. diagnosed by dealership
Oct 20, 2009 at 12:09 PM
