1991 Buick Regal Stalling
EDDIE BROOKS
Engine Performance problem
1991 Buick Regal 6 cyl Front Wheel Drive Automatic 100+ miles
The car generally runs great but after in town driving for a bit, 20 - 30 minutes it will die when you come to a stop, but will re-start as if nothing ever happened. Once it dies once it will continue to stall when coming to a stop several times. Some times times will run great not stall at all. It seems to run fine at highway speeds.
Apr 22, 2009 at 2:23 AM
  • 110,251 POSTS
Has the check engine light come on? Also, have you checked for vacuum leaks and the EGR?
May 3, 2009 at 5:29 AM
EDDIE BROOKS
No check engine light.
The ERG has been cleaned.
No vacuum leaks were found.
I took it to another repair station and they replaced the CAM sensor and fuel filter. Will see if it helped.
May 8, 2009 at 9:42 AM
  • 110,251 POSTS
Let me know if that takes care of it.
May 8, 2009 at 1:45 PM
EDDIE BROOKS
It seems to run well for a bit but then began stalling just as it had before. Same problem as before. I have been battlng this since last July. I have also had the spark plugs and spark wires replaced and the air control module replaced. I am stumped and about 1000.00 poorer at this point. Any ideas?
May 31, 2009 at 3:05 AM
