1991 Buick Regal plug change
G5DRIVER
Engine Mechanical problem
1991 Buick Regal 6 cyl Front Wheel Drive Automatic
How do you access the rear plugs on a 3.8L V6? I removed the front dogbone but the engine did not seem to want to tilt forward. I did not exert any real pressure on it to try and move it. Is there another trick to gain some room?
Jun 26, 2008 at 8:30 AM
LEGITIMATE007
  • 5,121 POSTS
you have to put it in neutral and use a cetain too to crank it foward, some people use a strap with a crank on it but the tool is so much easier and better.
its called an engine tilter, ebay has them
Jun 26, 2008 at 8:40 AM
