1991 Buick Regal My car wont get spark
1991 BUICK REGAL
MALS29DEVILDOGG
Electrical problem
1991 Buick Regal 6 cyl Front Wheel Drive Automatic
I have changed the spark plugs & wires, but the car still won't start. It will crank over, but wont start. There is no spark at the coil pack?
Feb 8, 2009 at 2:57 PM
  • CAR REPAIR CONTRIBUTOR
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 8, 2009 at 3:05 PM
JDL
  • 16,098 POSTS
Hello, I'm not sure of the litre size of the engine?
Without the rpm signal, among other things, no spark at the plugs.
Can you check B+ and ground to the ignition module? You can test the crank sensor,but, I can't rule out the ignition module.
Feb 8, 2009 at 3:11 PM
