1991 Buick Regal motor mounts
BOHOG44
Engine Mechanical problem
1991 Buick Regal 6 cyl Front Wheel Drive Automatic
is it possiable to change the top side motor mounts with out jacking up the engine? if i did it one at a time would the be enough support to change them?
Mar 2, 2010 at 9:24 AM
BLACKOP555
  • 10,386 POSTS
you can do one at a time but use a floor jack to unload the engine mounts itll make it alot easier to take the old one out and put new one in also makes it alot easier if you have to maneuver the new mount in order to get it to fit
Mar 2, 2010 at 10:10 AM
