1991 Buick Regal Battery Keeps Dying
120,000 MILES • V8 • 2WD • AUTOMATIC
SIEBFAM
I have had two batteries installed this year. Alternator is producing fine, new cables, but I believe something shorting out battery to causing it to go dead in about two days time, if it's not driven. Any suggestions?
Jul 9, 2009 at 12:03 PM
  • 31,937 POSTS
Hi there,
You need to do a current draw test, place an Amp meter between the battery pos & the cable, check with key out & doors closed, check current draw, if above about .2 amps start pulling fuses and check for which circuit is drawing, also disconnect the alternator as well as a faulty diode will cause this without affecting the charge rate to much, start here.
mark (mhpautos)
Jul 9, 2009 at 1:14 PM
