1990 Buick Regal engine cut out
126,000 MILES • 6 CYL • FWD • AUTOMATIC
MCKK4
drove 2 miles and car engine quit like it ran out of fuel..restarted it and off i go and then quit again ..pulled over restarted it 6 or 7 times quitting each time then started it and drove home ...i can start it it will run till i run up the rpm's and the outcome is the same ..seems to run out of fuel ..can you help pinpoint the problem
Apr 11, 2009 at 2:39 PM
  • 110,251 POSTS
First, if it feels like it is running out of gas, chances are it is. You need to check fuel pump pressure. Here is a how to video to help.
https://www.2carpros.com/dia/test_fuel_pressure.htm
Also, is the check engine light on?
Let me know what you find.
May 3, 2009 at 9:49 AM
