1988 Buick Regal fuel injector problem??
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
TTROSTLE
the car will idle just fine, when you put it in drive, reverse, or any other gear (not neutral) the car will start to move, then stall out and die. do you know what it could be?
Jan 20, 2010 at 2:05 PM
  • 75,988 POSTS
Try disconnecting the TCC solenoid and see what happens
Jan 20, 2010 at 2:11 PM
