old question...fuel pressure goes to within specs as soon as key is turned on,but,drops to zero immediately. The pressure is ok at idle but can't keep up during W.O.T.
new question...can a regulator leak without leaking out of vacuum port while running?
how do i check injectors for leaks?
can I replace check valve on pump?
Jan 26, 2009 at 11:36 AM
