1988 Buick Regal electric window motor driver side
1988 BUICK REGAL
AMACARPENTER
Interior problem
1988 Buick Regal 6 cyl Front Wheel Drive Automatic
I already Have door panel off but i cannot seem to find bolts that hold motor in place
Oct 18, 2009 at 11:10 PM
JDL
  • 16,098 POSTS
Welcome, if the motor has never been removed before, there may be poprivets holding the motor? You have to drill out the rivets, where applicable. Do you have good B+ and ground at the window motor, check circuit breaker? When you remove the motor, if it is faulty, the window will probably fall, if your not holding it.
Oct 19, 2009 at 4:56 AM
