1987 Buick Regal engine stalls
51,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEVIN55
recently engine started stalling my mechanic worked on this problem many hours, the carb is in good shape, he suspects the vacuum is causing the problem and mentioned that this engine type was one of the last with a carb. and has computer doing some functions of the carb.
Oct 22, 2009 at 4:21 PM
  • 110,246 POSTS
Has he checked manifold vacuum pressure? Was it low? Did he check fuel pump pressure / volumn?
Nov 24, 2009 at 2:36 AM
