1987 Buick Regal cranks want start
142,000 MILES • 6 CYL • 2WD • AUTOMATIC
GENE1988
  • 14 POSTS
this is a buick grand national 3.8 turbo,it will crank sounds like it is high in time,the motor kicks back
Feb 2, 2008 at 11:25 PM
MERLIN2021
  • 17,250 POSTS
Determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
In your case, if it's cranking slowly, the starter or battery cables should also be checked!
Feb 2, 2008 at 11:30 PM
