1985 Buick Regal Accelaration
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARMANDO19
hi i have an 85 regal t type and am having problems with accelaration stars off accelating very slow then takes off could it be my oxygen censor
Feb 19, 2010 at 4:47 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 19, 2010 at 8:27 AM
