1983 Buick Regal timing
1983 BUICK REGAL
78,000 MILES • 6 CYL • FWD • AUTOMATIC
MS.JAY87
my husband owns a 1983 buick regal and says that it needs to be timed exactly how would he go about doing this himself
Jul 31, 2009 at 11:01 AM
AKANYR
  • 52 POSTS
I have an 1988 Regal, 2.8L V6 engine. With my car there's two notches at the base of the tensioner pully. directly facing the notches is a single notch on the other part of the base. that single notch has to be directly in between the 2 notches opposite it. if the single notch is more to one notch or the other then he needs to change the drive belt. thats the ribbed belt that the tensioner pully rotates on the passenger side of the engine. the belt goes around about 7 or 8 pulleys. hope this helps. he will probably need a flash light to see the notches, even in the daylight.
Aug 18, 2009 at 10:41 AM
