Electrical problem
1982 Buick Regal 6 cyl Two Wheel Drive Automatic
i recently replaced the motor on my buick regal, after i got it in and all hooked up and tried to start it im not getting any power to the ignition coil, ive replaced the coil, and tested the ignition control module. The motor cranks fine, do you think the ignition switch is bad?
Mar 27, 2009 at 4:48 AM
