1981 Buick Regal Squeling Noise
1981 BUICK REGAL
999,999 MILES • 6 CYL • 2WD • AUTOMATIC
JEW1589
Hi, I Just Bout A 81 Buick Regal Limited, With a Olds 307 Engine And 350 Trans in It..Yesturday When I Bought It It Ran and Started Up Fine. This Morning Ther Was Fluid On The Concrete 1 Power Steering Fluid, Another Type of Fluid a Right At The Back of The Engine So When I Started It Up 2day It Squeled When I But In Reverse Or Drive It Stops But When I Accelerate It Begins Again....And When I Left It In Park To See If It Would Stop Squeling It Began To Smoke Around The Fan Belt, But Its Tight And The Pulley Is Moving....The Second Time My Headers Wear Smoking Also...Do You Have Any Ideas As To What Cold Be Causing This?
Sep 1, 2009 at 7:50 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
It sounds like the valve covers are leaking oil onto the headers. As far as the belts, is there a chance that oil or a fluid got on them?
Sep 4, 2009 at 8:01 AM
