1978 Buick Regal Wheel Bearing Replacement
9,000 MILES • V8 • 2WD • AUTOMATIC
JPELLICIER
  • 9 POSTS
This is a follow up of the answer I received. I already removed the 5'16"bolt. That bolt holds a cylinder like part (see picture white arrow- goes from top to bottom). That cylinder is the one I need to remove. I have hit it but it only comes out a little bit and stops coming out. How do I remove it- hitting it, using a puller, how!!? [img:ebdbec655c]http://www.2carpros.com/forum/automotive_pictures/262593_Photo0207_2.jpg[/img:ebdbec655c]
Sep 22, 2009 at 5:55 AM
DOCFIXIT
  • 18,828 POSTS
When you removed bolt was there a smooth shaft about 3/3" long after threads. In 50 yrs of car repair the pinon pin just slides out. is there damage to differential?
Sep 22, 2009 at 6:22 AM
JPELLICIER
  • 9 POSTS
yes that is the bolt I am talking about. There is no damage to the differential that we can see. Everything looks fine, but for some reason the after I removed the 5/16"bolt the pin doesn't slide off.
Sep 22, 2009 at 6:24 AM
DOCFIXIT
  • 18,828 POSTS
Go to each axle at brakes and pull maybe axel is up against pinion and won,t let it drop. there are to flats on pinion they maybe hanging on axle.
Sep 22, 2009 at 6:32 AM
JPELLICIER
  • 9 POSTS
Axles are not toching the pin. They are all the way back. This is a modified buick, with a 350 roller crate engine. We bought it like this.
Sep 22, 2009 at 6:49 AM
JPELLICIER
  • 9 POSTS
does the differential need to be in a specific position?
Sep 22, 2009 at 7:04 AM
DOCFIXIT
  • 18,828 POSTS
Can you roll pin around? is it free from spider gears?
Sep 22, 2009 at 7:05 AM
JPELLICIER
  • 9 POSTS
The pin does not roll around. It is supper tight
Sep 22, 2009 at 7:08 AM
DOCFIXIT
  • 18,828 POSTS
Hold one axle rotate the other . do spiders turn? if no look for weld slage on spiders.
Sep 22, 2009 at 7:17 AM
JPELLICIER
  • 9 POSTS
It is a posi-traction differential. Both axles will rotate
Sep 22, 2009 at 7:18 AM
DOCFIXIT
  • 18,828 POSTS
Not if you hold one how do you think the car turns outboard must turn faster or rear end would hop.
Sep 22, 2009 at 7:26 AM
JPELLICIER
  • 9 POSTS
We decided to take the car to a shop. That pin is not going anywhere and other people have posted the same problem on other forums and have not find a solutiuon either. Thanks for your help.
Sep 22, 2009 at 7:42 AM
