Engine Mechanical problem
1978 Buick Regal V8 Two Wheel Drive Automatic
I have a 1978 Buick Regal with a 383 stroker, solid roller cam (.525 lift, 245/250 duration), pro comp distributor, 10.5/1 compression, summit racing 750 cfm carb, the list goes on... I am having ignition problems related to temperature I believe. I recently took the car on a 400 mile road trip and I had major problems with backfiring and it didn't really want to rev up. I put in colder spark plugs and that helped for awhile but now it is back. It idles much rougher than normal and has a hard time reving up especially when warm to the point where I can't get the car to go faster than idle speed. Could the distributor be getting too hot causing the problem? The backfiring caused both header gaskets to blow out also, I don't know if that would affect it at all. Please help! Thank you in advance!!
Jun 5, 2010 at 8:15 AM
