I have a rattle in my front suspension. I was wondering what is causing the problem.
Mar 17, 2008 at 12:03 AM
✓Experienced Mechanic
Hi: It could be many things. It could be a loose shock, sway bar bushings... The best thing to do is take a rubber mallot and gently tap on steel items to see if you can find where it's coming from.
Nov 15, 2008 at 3:49 PM
BRAVESTAR1
Wow you still own your Buick Reatta. I wanted one of those so bad when it came off the showroom floor in 1990. Too bad I wasn't yet able to drive then.
