1988 Buick Reatta Brakes not working correctly
1988 BUICK REATTA
41,000 MILES • 6 CYL • FWD • AUTOMATIC
JYEAGER1
When I do a hard stop in traffic - car pulls left hard, then right - it seems to be unstable. It is getting worse over time. Calipers have been cleaned, brake lines replaced, brakes inspected. Mechanic does not get what is going on.
Apr 10, 2009 at 11:11 AM
Caused by contaminated linings, misadjusted brakes, a bad wheel cylinder or caliper, dragging brakes on one side or loose wheel bearings. Can also be caused by a mismatch of friction materials side-to-side on the front brakes or differences in rotor thickness, type or condition.
Apr 10, 2009 at 11:15 AM
JYEAGER1
Could it be ABS failure? Have you heard of this happening?
Apr 10, 2009 at 11:32 AM
Could be the ABS unit-The hydraulic pressure starts at the master cylinder then to the ABS unit then the wheels
Apr 10, 2009 at 11:36 AM
