2006 Buick Ranier RPM IS LOWER THAN NORMAL
42,000 MILES • 6 CYL • AWD • AUTOMATIC
BIGMOENYC
I TESTED AND IT SAID IDLE CONTROL SYSTEM RPM LOWER THAN EXPECTED....SORRY I DON'T MIND TO GIVE DONATION AS LONG I'M GETTING THE RIGHT ANSWER....I' HAVE BEEN CHECKING WITH DIFFERENT WEBPAGES BUT NO ANSWER..,,IF YOUR ANSWER WORK ......I'M GOING TO BE USING YOU MORE AND THIS TIME WITH DONATION 50 OR 100......THANK YOU
Feb 8, 2009 at 8:11 AM
BRIAN 1
  • 1,030 POSTS
if you could post the code this would help and give you a better answer. and more info on this problem.then will advise with a better answer.
Feb 8, 2009 at 12:49 PM
