2006 Buick Ranier Removing inside door panel to acess reaso
STEVEHECMAN
Interior problem
2006 Buick Ranier 6 cyl All Wheel Drive Automatic
Hi, The rear passanger door will not open from inside the vechile. It sounds like something either broke off or came loose inside the door . When you pull the door handle you can here something has come loose. My question is how do you remove the panel to get inside for repairs? I removed the two bolts from the arm rest but i'm afraid of breaking the tabs or something by trying to force out the panels. THANK YOU
Jan 14, 2010 at 2:59 AM
JROWE123
  • 5 POSTS
Have you checked the child safety button on the door if it has been accidently slid from it orginal position it will not open from the inside . this is a safety feature on a lot of cars now . This happen to me and it took me awhile to figure it out . You need to open the door from the out side and look for a small black button and slide it the opposite direction and it should work. Hope this helps.
Apr 22, 2010 at 5:50 AM
