Interior problem
2006 Buick Ranier 6 cyl All Wheel Drive Automatic
Hi, The rear passanger door will not open from inside the vechile. It sounds like something either broke off or came loose inside the door . When you pull the door handle you can here something has come loose. My question is how do you remove the panel to get inside for repairs? I removed the two bolts from the arm rest but i'm afraid of breaking the tabs or something by trying to force out the panels. THANK YOU
Jan 14, 2010 at 2:59 AM
