every time we put fuel in the fuel gauge goes to empty shows low fuel how do you reset it
Feb 15, 2010 at 10:28 AM
DENNYP
✓Experienced Mechanic
The problem is with the fuel level sensor. The contacts on it are probably corroded and causing erratic readings. The sensor will need to be replaced to correct the concern.
