2006 Buick Ranier Fuel Gauge
56,000 MILES • 6 CYL • AWD • MANUAL
CLBYERS
every time we put fuel in the fuel gauge goes to empty shows low fuel how do you reset it
Feb 15, 2010 at 10:28 AM
DENNYP
  • 1,824 POSTS
The problem is with the fuel level sensor. The contacts on it are probably corroded and causing erratic readings. The sensor will need to be replaced to correct the concern.
Mar 26, 2010 at 1:12 PM
