wont idle & runs rough when heater is on. also speedomp. has gone haywire dont know if its related or not.
Feb 7, 2010 at 12:14 AM
DENNYP
✓Experienced Mechanic
The speedo problem is most likley a bad instrument cluster. As for the rough idle, the heater should not affect on the idle quality. If it is in defrost mode, the A/C compressor will cycle. This will have an effect on idle quality.
The first thing to do is have it scanned for trouble codes. Use a scan tool to see if there are any cylinders misfiring.
Mar 26, 2010 at 1:25 PM
