2004 Buick Ranier NEED HELP
74,563 MILES • 6 CYL • AWD • AUTOMATIC
RICARDO MIRANDA
I HAVE CHECKED BOTH FUSE BOXES AND ALL THE FUSES ARE IN GOOD SHAPE. SOME LIGHT UP WHEN I PUT THE TEST LITE THEM AND SOME DON'T, BUT THE ONES THAT ARE NOT LIGTHING ARE NOT BLOWN. I HAVE NO POWER TO MY TAIL LIGHTS, SUNROOF, INTER LIGHTS, RADIO AND TO MY POWER SEATS. THE ONE THAT ARE NOT LIGHTING ARE THE THE ONES IN QUESTION . COULD THIS BE A BAD BCM OR COULD IT BE THE IGNITION SWTICH. I CHECK THE POWER GOING TO THE IGNITION SWITCH AND THERE IS POWER TO MOST OF THE WIRES BUT NOT ALL, NOT SURE IF THAT IS THE WAY IT WORKS. I WOULD LIKE TO KNOW FOR SURE IF IT IS THE BCM BECAUSE THAT IS A DEALER THING. THE IGNITION SWTICH I CAN HANDEL. THANKS FOR YOUR HELP.
Sep 15, 2008 at 12:40 PM
THIS IS MIKE
  • 686 POSTS
Check the small power wires coming from the starter. It sounds like one of them may be damaged or not connected properly.
Sep 16, 2008 at 9:21 AM
