2004 Buick Ranier Low beam headlights
42,000 MILES • 6 CYL • AWD • AUTOMATIC
71PIRATE
I started my vehicle last night and the headlights did not come on. I have the sensors that automatically turn them on. I have high beams, runnuing lights, tail lights, signal lights and fog lights, but no low beam. There are seperate fuses for each lamp, driver's side low beam, driver's side high beam and the same for the passenger side. I tried turning on and off the manual switch with no results. Other than fuses or bulbs, what would you suggest may be the problem?
Jan 3, 2008 at 12:44 AM
  • 110,248 POSTS
Hi:
Are you sure both bulbs are good? You could test them by checking for continunity. If they are good, my next stop would be the high beam switch. You would need to check for power in and out, but with air bags, I wouldn't recommend removing the steering wheel unless you're trained to do so.
Let me know if you have any other questions.
Nov 15, 2008 at 3:40 PM
