If you're feeling the vibration in the seat then it could be your rear wheel bearings. You can lift the car up in the rear and check for excessive play. Just rock the wheel in a 12-6 motion. There should be just a little bit of play, hardly noticeable. If it's excessive then they're worn.
SPONSORED LINKS
Wednesday, March 14th, 2007 AT 3:21 PM
