1991 Buick Park Avenue Bouncy Ride
DQDSRCARPRO
1991 park avenue, 3800 v6, auto, climate control,electronic level control [dynaride] 93k miles. Wife complains of bouncy ride. It is very bouncy on slightest bumps. Pushing down on all four corners the front two and right rear feel firm [down, up, slight settle] but the left rear bounces several time before settling. What should I look for?I understand the shocks for the elc are expensive. Can I replace them with a standard shock? How do I disable the air system. the air pump comes on and runs for quite a period when the car is turned off. Seems I saw somewhere that monroe sensatrack are a good compromise replacement.Any thoughts.
Thanks,
Don
Oct 12, 2007 at 1:13 PM
MERLIN2021
  • 17,250 POSTS
If you have an air strut on the car, I don't know of any replacement other than another air strut...But you better do something quickly, because if that air pump burns out due to excessive run time, your in for big money!
Oct 12, 2007 at 11:57 PM
Suggested Repair
Replace the failed air strut with another air strut rather than a standard shock. Do this promptly so the air pump does not run excessively and burn out.
Conversation Summary
The owner of a 1991 Buick Park Avenue with electronic level control reports a very bouncy ride. The left rear continues bouncing after being pushed down, while the other corners settle normally. The air pump also runs for a long time after shutdown. The owner asks whether the expensive ELC shocks can be replaced with standard shocks or Monroe Sensatrac units and how to disable the air system. The expert says an air strut should be replaced with another air strut and warns that excessive pump runtime can burn out the pump at high cost.
