Moaning Noise
ANDREAJ
I have a 2000 Park Avenue Buick 97500 miles, and I've noticed a moaning noise coming from the car when I turn the steering wheel, do you know what this might be.
Also, my car kinda has a vibration, especially when I go 60mph and above, also when I break from high speeds the car shakes pretty bad. Do you think I need to have the alignment checked?
Nov 21, 2006 at 2:17 PM
JUSTIN.DUNLAP
sounds like a bad wheel bearing.... if you turn to the left and it gets louder then its the right bearing and if you turn to the right then its the left wheel bearing. you can get one for about a hundred dollars and any part store . and there not to bad to replace if you have or rent the right tools from autozone. breaker bar, steering wheel puller, and a good breaker bar....... good luck
Justin Dunlap
Nov 22, 2006 at 9:18 AM
JUSTIN.DUNLAP
Also if its just moaning when you turn the wheel and your not moving then just check your power steering fluid.... most likely your just low ... but if its while your vehicle is moving the go back to my last reply....
Nov 22, 2006 at 9:20 AM
