gearshift
BUICK PARK AVENUE
MJNEH
1994 Buick Park Avenue 250,000 mi. Won't reverse unless you put it in low first , then reverse.
Jan 27, 2007 at 4:39 AM
JEFTFIELDS
  • 74 POSTS
sounds like your cable or cable ends on your shifter is broke.your shifter is riun buy a cable and that sounds like the problem.
Jan 27, 2007 at 8:11 AM
MATHIASO
  • 1,209 POSTS
Check the adjustement of the linkage. Move the shift lever from park position to the lowest DRIVE gear.Detent should be felt at each of these positions. if detent cannot be felt in either of the position, the linkage need to be adjusted.While moving the the shift lever, pay attention to the gear postion indicator.
Jan 27, 2007 at 9:49 AM
