Fuel injector
BUICK PARK AVENUE
MISS_RICKI
How do i replace a fuel injector on the car listed above it is a 2000 with 98,000 miles v.6 3800 series II?
Sep 22, 2007 at 4:08 AM
DENNYP
  • 1,824 POSTS
Hello, This guide will walk you through with diagrams below https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
https://images.2carpros.com/forum/automotive_pictures/102900_injector_1.jpg
https://images.2carpros.com/forum/automotive_pictures/102900_injector1_1.jpg
Fuel Injector Replacement (VIN K) Removal Procedure Tools Required J 34730 Fuel Pressure Gauge Notice: Use care in removing the fuel injectors in order to prevent damage to the fuel injector electrical connector pins or the fuel injector nozzles. Do not immerse the fuel injector in any type of cleaner. The fuel injector is an electrical component and may be damaged by this cleaning method. Important: The fuel injector is serviced as a complete assembly only. If the fuel injectors are found to be leaking, the engine oil may be contaminated with fuel. Relieve the fuel pressure. Refer to Fuel Pressure Relief Procedure . Remove the fuel rail. Refer to Fuel Rail Assembly Replacement . Remove the fuel injector retaining clips (2). Remove the fuel injectors (3). Remove the fuel injector upper O-ring (1). Remove the fuel injector lower O-ring (5). Important: Fuel injector O-rings should always be replaced whenever fuel injectors are serviced. Each fuel injector is calibrated for a specific flow rate. Be sure to use the correct part number when ordering replacement fuel injectors. The fuel injector lower O-ring (5) uses a nylon collar, called the O-ring backup (4), to properly position the O-ring on the fuel injector. Be sure to reinstall the O-ring backup, or the sealing O-ring may move on the fuel injector when installing the fuel rail. If the sealing O-ring is not seated properly, a vacuum leak is possible and driveability complaints may occur. Remove the O-ring backup (4). Installation Procedure Important: When ordering new fuel injectors, be sure to order the correct injector for the application being serviced. The upper and lower fuel injector O-rings use different part numbers. To identify the correct O-ring, the upper O-ring is black and the lower O-ring is brown. Both O-rings are the same size but consist of different material. The fuel injector lower O-ring uses a nylon collar, called the O-ring backup, to properly position the O-ring on the injector. Always reinstall the O-ring backup, or the sealing O-ring may move on the injector when installing the fuel rail and result in a possible vacuum leak. Important: Fuel injector O-rings should always be replaced whenever fuel injectors are serviced. Coat all new O-rings with engine oil before installing. Install the fuel injector back up O-ring (4). Install the fuel injector lower O-ring (5). Install the fuel injector upper O-ring (1). Install the fuel injector to the fuel rail (3). Install the fuel injector retaining clips (2). Install the fuel rail. Refer to Fuel Rail Assembly Replacement . Install the fuel injector sight shield. Refer to Fuel Injector Sight Shield Replacement in Engine Mechanical.
Oct 1, 2007 at 2:29 PM
DAVE 669
My question is how do you remove the fuel injector rail. How much voltage does it take to open the injector i have a clogged injector and need to clean it. Thankyou
Sep 25, 2019 at 11:59 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
It's a 12v injector but I don't know how you expect to be able to clean that internally yourself. It should be replaced.
GBAKER09
Computer problem
1995 Buick Park Avenue 6 cyl Front Wheel Drive Automatic
ok i got thi sbuick and the motor was lock up i have replace the motor and alternator,starter,battery,spark plugs/wires and i put the new motor in an it crank up for maybe 2 to 3 sec and jus cranked it maybe 3 time because i knew it was bad gas the fuel pump was workin it jus stopped and i have changed out the fuel pump and it was another problem the fuel tank sending unit was damaged and sum wire to the fuel pump was burned the have been replaced and an did change out the fuel tgank sending unit just connected sum wire from the wire from the fuel sending unit up to the fuse box and now that i have done that it still will not start it jus turns over and not starting the fuel injector are not shooting the injector wire have power going to them still not shooting gas threw but the fuel unit is working and the gas in getting to the injectors just not coming out and can yu tell me the problems that it could be and am thinking the computer on the car is bad or another wire is damaged sum where or its the fuel injectors...but the fuel injector was working tell fuel pump stuff went down plz hep.....
i have spend alot of money
alternor
battery
started
motor
wiring redone
fuel pump
etc...
Could be the computer ground driver circuit for the injector-Are you getting a snapping blue spark and the correct fuel pressure-
