Where is the ECM located in this car
2002 BUICK PARK AVENUE
185,000 MILES • 6 CYL • FWD • AUTOMATIC
PITIN
This car starts fine and run good for a while then it shut down then it will run and do the same thing. The fuel pum and ignition control module has been replace, I check the spark when you star it but the engine do not run and is very good. I bought an ECM thinking that this intermitent problem is cause by it, but do not know where it is located, does any body knows? Thanks a lot.
Nov 9, 2010 at 8:57 AM
You have to remove the air cleaner top cover to get to it-see pictures below:
https://images.2carpros.com/forum/automotive_pictures/12900_p1_9.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_p_3.jpg
Nov 9, 2010 at 9:19 AM
