2002 Buick Park Avenue Jerking When Taking Off
2002 BUICK PARK AVENUE
209,700 MILES • 6 CYL • FWD • AUTOMATIC
CARRKENNETH72
When you take off after about 20 miles an hour the car will jerk a couple of times then seems to run smoothe as if nothing is wrong. The vehicle started doing this about two weeks ago and does not jerk every time it is erratic and I was wondering if this could be in the transmission or possibly a fuel injector problem
Feb 21, 2010 at 9:02 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 21, 2010 at 9:21 AM
