2002 Buick Park Avenue I think I need a tune up
191,001 MILES • 6 CYL • FWD • AUTOMATIC
LNDA
Just 2 days ago, I had a flat repaired. (I know fixing a flat won't cause engine problems) After I left the service center, the car starts acting weird. I could smell something like something burning but I thought maybe it was outside. So anyways, It's sluggish and idling weird now. It's a well kept car and everytime something is needed done to it, I usually do it myself or get it done. When I got home I opened the hood and the alternator was making a slight sound after the engine was turned off. So I'm totally confued on what's happening with it. I'm going t change the air filter and check the plugs. Can it just needing a tune up cause this to happen?
Jun 26, 2008 at 11:34 AM
LNDA
This is a continuation of what happened when I took the car in. Don't go to Meineke! They over charge badly and messed up my car! They goofy tech crossed the wires on the coil pack for the number 5 and 6 spark plugs. That was "his" way of tuning up my car I guess. When I told them it was worse and something was wrong they told me I needed a air flow sensor, which wasn't really out, and a fuel injector on the number 6, which wasn't really clogged. Then the manager had the nerve to tell me that I should take the sensor off and spray it with computer cleaner and dump (in his actual words) "a butt load" of tekron fuel additive into the tank. But there was nothing else they could do. I took the car to Gateway tires and service center, they went ahead an replaced the fuel injector, because I had asked them to, the sensor wasn't bad at all. The tech at Gateway then told me it's still running really bad. So they ran diagnostics on it. It came up "engine misfire", The guy then noticed the wires had been crossed. My car runs fine now. As soon as he uncrossed the wires and started it, it was like a new car. By the way, the injector was starting to clog and it cost me $51.00 cheaper for the part than Meineke was going to charge me.
Jun 29, 2008 at 1:46 AM
