2001 Buick Park Avenue power windows and radio not working
2001 BUICK PARK AVENUE
78,000 MILES • 6 CYL • FWD • AUTOMATIC
BRIAN335
The power windows and playing of the radio does not work at times. I can start the car 1st thing for the day and all electical works. stop it and sart again and the power windows, radio and sterring radio buttons do not work. OBD2 test revealed no codes. check engine light stays on if ignition switch is on postion without starting the car
Apr 17, 2010 at 11:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
May need to remove and test the Accesory (ACCY) relay as well as the Retained Access Power (RAP) relay.
When the windows are inoperative, have you tried using the other doors' window switch to see if the window operates with it?
Apr 18, 2010 at 5:10 PM
BRIAN335
Thanks for your help I figured it out that it was the wiper motor fuse was loose
[quote:197b0235ec="bluelightnin6"]Hello and thanks for donating
When the windows are inoperative, have you tried using the other doors' window switch to see if the window operates with it?[/quote:197b0235ec]
Apr 20, 2010 at 3:34 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Apr 22, 2010 at 6:27 AM
