2001 Buick Park Avenue power windows
2001 BUICK PARK AVENUE
43,000 MILES • 6 CYL • 2WD • AUTOMATIC
WINTERLAND
The rear passenger side power window goes up but not down. It does not make a difference if I try using the switch mounted on the door armrest or the driver's door armrest. What do I do?
Jun 7, 2010 at 5:42 AM
  • 110,244 POSTS
One of the switches is bad. You need to check both for continunity when the switch is engaged in both directions. I would recommend starting with the driver's door. It supplies poiwer to the rear one.
Jul 23, 2010 at 4:33 PM
