2001 Buick Park Avenue How to replace Brake light switch
174,000 MILES • 6 CYL • FWD • AUTOMATIC
TSHERK80
My rear lights keep on burning out every so often. last week I changed 'all' of them and they were all working, but 2 day later only the brake lights stopped working (when i brake) my mechanic told me it could be a stop light switch.
How would I replace the stop light switch?
Feb 18, 2010 at 2:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
brake switch is under dash, on brake pedal bracket. disconnect battery, then disconnect switch and unbolt to replace it.
Feb 18, 2010 at 2:53 PM
TSHERK80
I went ahead and replaced the switch, but everytime I hit the brake the fuse blows, no matter between the new or old witch.
where hould I go from here?
Feb 21, 2010 at 8:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if fuse keeps blowing then this indicates a short in that specific circuit. check the wiring at the brake switch as well as at the brake light housings
Feb 21, 2010 at 10:35 AM
TSHERK80
All th wire's at the brake looked fine, what do you mean by the 'houing'? and what am I looking for?
Feb 21, 2010 at 11:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the housings is where the bulb seats at each tail light assembly. inspect the wiring at these housings.
Feb 21, 2010 at 11:44 AM
TSHERK80
You were right! One of my bulbs were bad and rusty, took it out and everything works now.
Thank you very much.
Feb 22, 2010 at 3:51 AM
