2001 Buick Park Avenue Brake light
12,434 MILES • 6 CYL • FWD • AUTOMATIC
How do you remove the bulbs in the rear deck brake light panel? Thanks for the help.
Jan 15, 2008 at 4:28 AM
DENNYP
  • 1,824 POSTS
https://images.2carpros.com/forum/automotive_pictures/102900_255308_1.jpg
High Mount Stop Lamp Replacement Removal Procedure Remove the push-in retainers (1) from the center high-mounted stop lamp (4). Perform the procedure from the inside of the rear compartment. Turn the bulbs and the sockets counterclockwise in order to remove the bulbs and the sockets from the center high-mounted stop lamp (4). Remove the bulbs from the sockets.
Jan 17, 2008 at 11:51 AM
