2000 Buick Park Avenue wheel bearing assembly-front
PAT STEVENS
Doing a replacement wheel bearing assembly. How many pounds of torque is required? Front right wheel.
Jul 24, 2010 at 12:44 PM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_2000_buick_park_ave_wheel_bearing_specs_1.jpg
First of all thank you so much for your donation.There is all the torque spec's you need.
Jul 24, 2010 at 1:06 PM
PAT STEVENS
Your answer doesn't answer my question. How many ft. lbs pressure does it need?for the wheel bearing. I paid $5 and got no information. Please help immediately.
Jul 24, 2010 at 1:31 PM
SATURNTECH9
  • 30,869 POSTS
I posted the torque spec's for the other thing's i thought you might need spec's for also.It's 70ft foot pound's for the hub and bearing assembley bolt's and 107ft pound's for the axle shaft nut.Brake caliper bolts are 38ft pound's and wheel lug nut's are 100ft pound's.So sorry about the confusion.
Jul 24, 2010 at 1:49 PM
PAT STEVENS
[quote:2575c58bcd="saturntech9"]I posted the torque spec's for the other thing's i thought you might need spec's for also.It's 70ft foot pound's for the hub and bearing assembley bolt's and 107ft pound's for the axle shaft nut.Brake caliper bolts are 38ft pound's and wheel lug nut's are 100ft pound's.So sorry about the confusion.[/quote:2575c58bcd]
Thanks, I couldn't read the column that said 'ft. lbs', so I didn't make it out. I have it now, thanks.
Jul 24, 2010 at 1:58 PM
SATURNTECH9
  • 30,869 POSTS
Your welcome sorry again about the confusion and thank you for using 2carpros.
Jul 24, 2010 at 2:01 PM
