2000 Buick Park Avenue water on the floor on the passenger
2000 BUICK PARK AVENUE
CRACKUN
Interior problem
2000 Buick Park Avenue 6 cyl Automatic 71000 miles
water on the floor of the front seat on the passenger side. wondering if there is a condensation drain that is plugged and draining onto the floor of the car
Oct 2, 2008 at 7:09 AM
  • 110,240 POSTS
Hi:
Do you only notice the water after using the AC? If so, I think you are correct. It sounds like the drain is blocked. If you can get under the car, locate the drain hose. It should be low on the car's firewall. Move it around or take a thin wire to unclog it.
Let me know how you make out with it.
Oct 3, 2008 at 12:23 AM
