2000 Buick Park Avenue RPM drop when holding steady speed
125,000 MILES • 6 CYL • FWD • AUTOMATIC
DESMOINES08
I have had this issue for a little while now. The auto would accelerate without any issues, but once i have reach a certain speed and mantain it for a few seconds the RPM drop by about 400. So i am holding the pedal steady to keep the auto at the speed, the RPMs drop by 400 or so and then if i press the pedal down the car is struggling to do so, then after a few seconds of struggling it starts to accelerate. If i am in the same situation, but this time i let go of the pedal a little and then press it again then the auto accelerates without any issues. This happens at any given speed it seems like, but only if i maintain one speed. While accelerating it does not happen.
Mar 13, 2008 at 5:26 AM
  • 75,988 POSTS
Check the fuel pressure and the throttle position sensor-
Mar 13, 2008 at 5:41 AM
DENNYP
  • 1,824 POSTS
You should also monitor the TCC lock-up and duty cycle on a scantool. Make sure it isn't a torque converter problem.
Mar 14, 2008 at 2:58 PM
